while the trans is off.....
Old Jan 8, 2009 | 03:47 PM
ChefJ's Avatar
Default while the trans is off.....
What other things should be cleaned up or gotten rid of while the tranny is off. I am full ems and the car will be used primarily for track use.
Are there any lines that should be upgraded or any lines that can be remioved, i.e. evap lines and whatnot. Thanks for any advice.
Old Jan 8, 2009 | 05:16 PM
nightcrawler7188's Avatar
might as well get a SS clutch line
Old Jan 9, 2009 | 10:53 AM
siadam's Avatar
I'm sure you pulled your air pump out already. IAC could be removed for a track only car.
A/c and lines? Note:I'd only pull a/c if it was track only.
Depending on year, you could pull the slave cylinder dohickey.
Old Jan 9, 2009 | 11:30 AM
03silver2000's Avatar
pull your slave cylinder? WHAT?
Old Jan 9, 2009 | 11:48 AM
Wardroid's Avatar
check for clutch wears..
Old Jan 9, 2009 | 12:06 PM
btstone84's Avatar
get yourself a twin disc clutch
Old Jan 9, 2009 | 05:56 PM
RAIN H8R's Avatar
depends how much time you have, but remove the underbody coating haha
Old Jan 9, 2009 | 06:16 PM
ChefJ's Avatar
AC is gone and so are the lines. I was just more interested in what could removed/changed while the tranny was out. The other things can be taken off at any time. I guess I will just clean up the tranny and slap it back on.
Old Jan 9, 2009 | 07:30 PM
ChefJ's Avatar
Of the 4 lines that go from the fuel tank up to the engine bay which can be removed?? Which lines are the evap lines that can be removed once ems is installed.
Cgb569
Apr 21, 2015 01:25 AM
BerlinaBlack_AP1
Oct 3, 2010 06:55 PM
twohoos
Sep 20, 2006 09:59 AM
Wesmaster
Dec 3, 2001 11:59 AM
Apex76A2
Aug 9, 2001 03:55 PM
