Why am I Overboosting?
Old Nov 21, 2006 | 07:14 AM
Raven628's Avatar
Originally Posted by ya@inlinepro,Nov 21 2006, 11:05 AM
any dramatic weather changes?
Always hot over there.
Just how it is. weather wise.
Old Nov 21, 2006 | 07:18 AM
ya@inlinepro's Avatar
totally forgot where he was...
Old Nov 21, 2006 | 08:41 AM
XclusiveAutosports's Avatar
Without a vac line the wastegate doesn't know when to open, it needs a boost signal. Its kind of like hooking up a BOV without a vac source, it won't work too well.
Old Nov 21, 2006 | 10:59 AM
Ray K.'s Avatar
if he was just running of the wastegate spring tension before, I don't think the vacuum line from the boost signal source to the wastegate is the answer he is looking for here.
Old Nov 21, 2006 | 11:59 AM
I am willing to bet that he had a vac line on there before though.
Old Nov 21, 2006 | 04:17 PM
Venomous S's Avatar
Funny because I saw this post last night and no one posted about the vacuum line but i decided not to because I was giving him the benefit of the doubt that in his previous setup he did have a vacuum line connected to it so that couldn't be it
Old Nov 22, 2006 | 03:51 AM
jakub2000's Avatar
Bad news is, I drove the car for over a year with open nipple on the compressor and WG. Cody's or my fault, no one told me
A manual bost controller solved the problem. Car is on the dyno now, at 7psi I see 328whp, timing untouched so far...there goes the "DIY porting is retarded" therory 98RON fuel btw.
Old Nov 22, 2006 | 04:15 AM
GDM S2K's Avatar
It wouldnt be codys fault at all, why would you even bring it up as it might have been his fault. judging by the non existant vac line on the w/g ide say your mecahnic is prob to blame for that issue. its not codys job to tell you how to install it. and I believe in every w/g there is direction. also dont think companys like Tial and Hks would make hole on the sides of their w/g for fun.
Great numbers at 6 psi now lets see the dyno graph. until theres a graph is just a myth
Old Nov 22, 2006 | 04:19 AM
Ray K.'s Avatar
So you've had a boost leak all this time eh. Car sound much different now that it's fixed?
Old Nov 22, 2006 | 07:08 AM
Quivers's Avatar
Banned
It dropped about 40 degrees and my integra slowly boosted more and more as the temps dropped, I went from 8 to 12 psi.
