Wideband and O2 Sensor.
Not sure if this goes in Engine management or F/I. So mods, move if need be.
I had an Innovate LC1 Wideband/Gauge hooked up into my turbo down pipe. The down pipe has 2 bungs. One for the Primary O2 sensor and one for the Wideband sensor. The secondary O2 sensor is plugged into the test pipe.
I'm changing to a supercharger setup with KPro so I'm going back to the stock header. The problem is that the stock header only has one bung for the primary sensor. Can I replace either the Primary or Secondary sensor with the wideband sensor? Will doing this ruin the accuracy of the AFR reading? Also, will doing this pass/fail emissions?
To avoid the extra downtime and cost, I want to avoid having a bung welded to the stock header.
You can run without narrowband sensor with Kpro as well- right off map
To run both, you only need two bungs. (heh-heh, two bungs) That is, put the primary in the test pipe, wideband in the header... secondary can be removed
EDIT:not sure about Flash Pro if that's what you have.
I'm confused now. From what I see from the 2nd post, it sounds like I have to move the primary sensor (header) into the secondary sensor location (cat / testpipe). And then put the LC1 wideband sensor where the primary sensor used to be. Right? My question is, how can I get the primary sensor to reach the cat?
I do already know about the LC1 being spliced into the ELD wire.
