Wierd Idling Problem
Old May 11, 2009 | 07:55 AM
dsddcd's Avatar
I have heard several stories about meth shorting the TPS, but then evaporating before it can be diagnosed.
Old May 11, 2009 | 08:17 AM
JoeyBalls's Avatar
yeah I had one TPS burned out due to METH, I was injecting it to early on so a lot of it was finding its way into the TPS, I checked the VOLTS though the range of the TPS it was smooth from .35v-4.60v at WOT, I will clean the IACV tomorrow
I have an E-manage for the fella who asked so it doesnt hide CEL codes
Old May 11, 2009 | 08:35 AM
RichV's Avatar
Alright, dumb question, what is the IACV?
Old May 11, 2009 | 08:39 AM
s2000Junky's Avatar
Idle-air-control-valve.
Old May 11, 2009 | 09:10 AM
JoeyBalls's Avatar
I do hear they get gunked up, I figure my 91k plus Methanol combo may have gubked it uo, but I dunno the sympthoms of a faulty IACV, I searched but found just how to clean it,
Old May 11, 2009 | 09:17 AM
s2000Junky's Avatar
^^^ sounds reasonable considering your issue. I would go ahaed and do it. Shouldnt take but a few minutes. Let us know what happens. I'm running meth now too and what to know what kind of corks to expect down the road.
Old May 11, 2009 | 09:32 AM
Revenge's Avatar
Mine has been doing something like this as well, runs great then seems to run a bit funny, I think I may just need new spark plugs.
Old May 11, 2009 | 10:10 AM
JoeyBalls's Avatar
I think I need new plugs too, but I dont think plugs would cause this type of thing. I am in the middle of polishing my car, my work Wheels are supposed to be here today so I gotta make my car look purdy
Car runs fine while driving so Im not too worried, at least not yet.
The more that goes wrong the more I learn ya know
I just checked UPS' the peice of shit lazy fuk of a driver was too lazy to drop it off so he put that no one was home to sign for it. UNREAL I swear to god some F---- people. I have been polishing my car since 8am this morning
Old May 11, 2009 | 10:24 AM
ChefJ's Avatar
This ones easy. if its not the above, which it probably isn't its a vacuum hose that has come off somewhere.
Old May 11, 2009 | 10:54 AM
DeadZero's Avatar
i signed in on here from school just to tell you joey LOL.
Its the Intake-Air-Control-Valve... it just happened recently to my car and DO NOT DRIVE YOUR CAR HARD!!! you need to get this fixed or you could blow your motor.
The intake censor is getting wet from your methanol (what happened to me) and it is messing with your electrical system and it will cause the car to run lean. this is very important joey. Try avoiding driving the car at all times until this is fixed.
This became an issue when i recently installed the SOS throttle body and there is a boost leak and a methanol leak with this system ( i guess there throttle body isn't designed for high boosted applications)
Last friday i mailed SOS back there throttle body to be inspected and repaired/replaced but you should be very well aware that the car is at risk of running too lean.
