winter build up
Old Oct 16, 2006 | 12:18 PM
Black Nugget's Avatar
My mistake - 7405 is correct, not 7514. It was approximately 1 year ago that I made the purchase of these spark plugs, I simply forgot over time.
Old Oct 16, 2006 | 12:22 PM
kane.s2k's Avatar
Originally Posted by JDM S2000,Oct 16 2006, 01:12 PM
People have been running these for years on FI there is nothing wrong with them
So what? You are suppose to be running resistor plugs on this car. It can cause electrical issues if you don't. The cost is the same, he gave the part #, and it's the correct plug. People have been doing certain things, buying certain things, using certain things forever now but if you can have something better without any sacrifice then why not?
I use the 7173's myself but I will be swapping out to the plugs he's mentioned on the first oil change.
Old Oct 16, 2006 | 12:34 PM
Kane does make a very good point! If you can find something that is the same cost, yet is more similar to the stock spark plug... why not!
To those who do not know what 'Resistor' is in the spark plug - here is the article by www.sparkplug.com :
Originally Posted by SparkPlug.com
Resistor
At the moment the spark jumps the gap it causes a high frequency burst of energy, this is known as RFI (radio frequency interference). This is why resistor spark plugs were introduces in the mid 1960's. Placing a resistor within the spark plug suppresses the RFI. Without resistor plugs in your car you can experience static on your radio as well as interfere with other sensitive electronic equipment. Some later model vehicles as well as newer Powersport engines must use resistor plugs for a proper "talkback" to the electronic ignition. Outboard marine Capacitive Discharge Ignition (CDI) such as used on some Johnson and Evinrude marine engines require a special inductive type resistor (such as a Champion Q-type or NGK Z-type). Use of non-inductive resistor type plugs on these motors can cause misfire and poor performance.
For automotive CDI high output ignition systems systems (such as Mallory, MSD, Crane and Accel), refer to Resistor plugs for race engines for information relative to modified motors.
This line alone - "Use of non-inductive resistor type plugs on these motors can cause misfire and poor performance." makes me want to swap out the NGK 7405's that I have.
Old Oct 16, 2006 | 03:06 PM
WolfInSheepsClothing's Avatar
I agree
Old Oct 16, 2006 | 03:22 PM
geists2k's Avatar
And people do all sorts of stupid stuff until they figure out the right way to do it. If I had four spare hours, I could list out here all the mistakes I and others have made along the way during my turbo build up.
I take the advice of my tuner, and you can choose not to. It's your call and you can do whatever you want.
Old Oct 16, 2006 | 04:05 PM
passmans2kny's Avatar
ah i knew i forgot something. should i get the aem map sensor or is there something better you guys would recomend?
Old Oct 16, 2006 | 04:08 PM
geists2k's Avatar
I have the AEM 3.5 bar MAP sensor and it works well.
Old Oct 17, 2006 | 02:46 AM
QUICK_AG's Avatar
Interesting, I'm doing the same thing this winter as well. Will be following this to see how things turn out. Good luck
Old Oct 17, 2006 | 05:36 AM
JDM S2000's Avatar
Banned
Ok so i ordered the 7173s yesterday, then I read this thread and called and switched to the 7405s
WHICH ONE IS CORRECT, FOR ME AND FOR THE GUY DOING THE BUILD
Old Oct 17, 2006 | 08:01 AM
Everyone has their own recommendation - personally I am using the AEM 3.5 Bar and it does the trick!
After doing a bit of research on spark plugs, while learning the difference between resistor and non-resistor design I will be going with the NGK BKR7E. They are Copper Plugs, Resistor, and 1 Heat Range Colder than stock.
Sure, with how much boost I plan to run going 2 Heat Range Colder would be better... however, I have never been to fond of Iridium Plugs. On top of that, the 7405 Plugs are Non-Resistor design.
