wiring AEM Tru Boost with AEM EMS Series 2
Old Jul 12, 2011 | 07:19 PM
gnehc1's Avatar
Default wiring AEM Tru Boost with AEM EMS Series 2
I'm trying to figure out which is the correct or best way to wire the boost solenoid. I did a search but wasn't able to find a definite answer.
1) The AEM Series 2 (30-6052) manual says to connect one wire of the boost solenoid to a switch 12+ volt line and the other wire to pin D16 on the EMS.
2) However on the Tru Boost (39-4350) manual, it shows the two wires of the boost solenoid being connected to the gauge/controller.
For those with the AEM Series 2, which way (#1 or #2?) did you guys connect it? What are the advantages and disadvantages of each setup? I don't want to splice wires into the EMS if I don't have to.
Thanks,
Cheng
Old Jul 17, 2011 | 06:59 AM
Killer_B's Avatar
<<Bump>>
I might need this too..
Old Jul 17, 2011 | 09:15 AM
razzele's Avatar
Use the 'D block' connector and follow the pin instructions provided in your AEM instruction booklet. Polarity of the wiring is irreverent.
edit- oops that is only really useful for aem 1052 series 1.
Old Jul 17, 2011 | 12:23 PM
gnehc1's Avatar
After thinking about it back and forth for a while, I think I'm planning to wire the solenoid to the Tru Boost gauge/controller, or else you may not be able to take advantage of the Tru Boost gauge/controller, like it is wired in the Tru Boost manual.
I think if you ONLY had the MAC solenoid and no Tru Boost gauge/controller, you would hook it up to the series 2 EMS as an accessory like below.
Old Jul 17, 2011 | 04:08 PM
AusS2000's Avatar
It depends which device you want to control the solenoid.
If you want the EMS to control it connect one wire to D16 (or whatever pin controls the boost solenoid on your EMS) and the other the +12V.
If you want the Tru Boost to control the solenoid (and as you have one I'm guessing that's what you want) connect both wires to the Tru Boost. It supplies +12V on one and ground on the other. Not sure which one it switches but it's irrelevant.
The EMS and Tru Boost provide the same function, but only one or the other can do it. The Tru Boost provides better optional settings and monitoring in the cabin.
Old Jul 17, 2011 | 05:57 PM
gnehc1's Avatar
Thanks for the confirmation. Yes, I have the Tru Boost gauge/controller and I'd like having more manual control using the gauge/controller.
Old Jul 17, 2011 | 06:30 PM
AusS2000's Avatar
Ok, just to reiterate, if you're using the Tru Boost the EMS is not connected to the solenoid in any way.
Old Jul 17, 2011 | 06:37 PM
gnehc1's Avatar
Understood. I'm going to follow the Tru Boost manual instructions and connect the solenoid directly to the gauge/controller.
Old Jul 17, 2011 | 07:11 PM
AusS2000's Avatar
Old Mar 1, 2013 | 10:11 PM
Big Jeffrey's Avatar
In just about any AEM Tru Boost Gauge and Controller product description there is text that says that the product is STANDALONE meaning it can function all on its own even without an ems.
