DIY: HKS Hi-Power install
Old Nov 16, 2006 | 06:42 AM
VeilSide AP1's Avatar
Default DIY: HKS Hi-Power install
HKS Hi-Power exhaust system D.I.Y Install
The Car
Stock exhaust
Start by removing the lower stab. bar
Then loosen up where the exhaust meets the cat
Loosen up the hanger aswell
unmount the exhaust, you will need 2 people for this
Parts
Mount the mid pipe of the HKS on the hanger and position flange provided
Bolt up and tighten
install hardware and flange at the end of the mid pipe
Mount the second piece of the HKS insert flange and bolts
tighten up hardware
since i have the VeilSide Ver.1 lip kit i had to more or less check if it would comprimise the rear lip
install hangers on exhaust and mount them, try using some lube to get them in
Now apply flange and hardware to connect the canisters to the rest of the exhaust and tighten
Re-install the factory stab. bar and your done
Final product
Manufactured 8/29/06
Old Nov 16, 2006 | 06:49 AM
G127's Avatar
Nice DIY pictures.
Almost time for some new rear tires.
RXDI's Avatar
Great job, this may need to be a stickie.
Now all you need is a Berk Test Pipe and your set. The combo sounds badass!
Old Nov 16, 2006 | 06:54 AM
[QUOTE=G127,Nov 16 2006, 07:49 AM]Nice DIY pictures.
Old Nov 16, 2006 | 07:33 AM
05berlinas2k's Avatar
that driver side rear tire is worse than mine
looks like your running some crazy camber for it to wear that bad
anyways nice write up thanks
Old Nov 16, 2006 | 07:40 AM
stylinhonda's Avatar
Great write up! Any little tips? How does the exhaust sound when it's brand new? Does it change any once it gets broken in? I should be getting my HKS soon, but will not have a lift for the install. How did everything match up? Good fitment?
Old Nov 16, 2006 | 08:20 AM
Yea i need to get an alignment
[QUOTE=stylinhonda,Nov 16 2006, 08:40 AM]Great write up!
Old Nov 16, 2006 | 08:32 AM
Johnny Sack's Avatar
nice DIY. i find it easier to bolt the whole exhaust together and just install it as one piece just like the stock exhaust.
HKS Hi-power is for pimps! i love my mine!
Old Nov 16, 2006 | 08:38 AM
WashabiS2K's Avatar
man those tires are bald.. i dont know who would really require a DIY for an exhaust install i remember when my HKS used to be that shiney and new.
Old Nov 16, 2006 | 09:47 AM
koen's Avatar
Looks good
I'm thinking of buying one myself. How does it sound?
Does anyone has an audio file?
