LED DRL concept
Old Jun 24, 2015 | 07:31 PM
S_special's Avatar
Default LED DRL concept
just a little concept for porsche inspired DRL headlights
Old Jun 25, 2015 | 06:25 AM
sdosmil77's Avatar
I like it on porsches so I was gona do same to mine.
Old Jun 25, 2015 | 11:09 AM
Iradier310's Avatar
Just do a highbeam retrofit and use the panamera shroud. Get a halo behind it and done.
The retrofit source sells that shroud.
Old Jun 25, 2015 | 02:07 PM
Bizhan's Avatar
I appreciate the work put into it but I'm of the opinion that LED DRL strips or any variation thereof should stay on cars that come with them from the factory. Most of the time it just looks out of place when put on cars that didn't come with them, regardless of design/placement.
Old Jun 25, 2015 | 02:14 PM
Adrenalize's Avatar
Though I do like these more than the usual strip ones.
Old Jun 26, 2015 | 10:24 AM
LowandSlowDC5's Avatar
Excuse my ignorance, I usually never have to ask what a part is. Never payed much attention to lip protectors but lately thought about getting one. Which one is pictured on the car in the topic starters first post?
Thanks!
Edit: Never mind, I looked at his build thread and got my answer
Old Jun 26, 2015 | 10:42 AM
juntsky's Avatar
i was going to come in here and hate this but i love it. this actually looks like it could be factory and looks great. Likely due to the fact that its not strips of leds. nice work.
Old Jun 26, 2015 | 10:51 AM
engifineer's Avatar
LED's do not always like working in high heat, so you will likely need to do some testing to figure that out. On other cars, I have seen people replace the turn signal bulbs that exist in the headlight housings with LED modules and they typically fail surprisingly quickly due to the heat of the headlight. It will be highly dependent on the LED and electronics used and how the housing is designed AND the heat produced by the headlights .. so it may work beautifully.
Old Jun 26, 2015 | 10:53 AM
engifineer's Avatar
I think they generally look cheap and crappy on cars that come with them too. There are exceptions, but I generally dont like them.
Old Jun 29, 2015 | 10:54 PM
pdxl's Avatar
How hard was the mod?
