Moddiction is now offering an aluminum S2000 engine heat shield. This is great for cleaning up the look of the engine bay while also blocking hot air from reaching the intake filter on many intake setups.
Installing is as easy as removing 2 pre existing bolts, putting heat shield on and re bolting down the 2 bolts into the vtec solenoid. 5 minute install.
This is a perfect match for the K&N FIPK intake as well as many other intakes available and even the oem airbox.
It is offered in a textured black powder coating to nicely match the oem look.
I use black oxidized stainless steel hardware on all heat shields. (Shown is a non black oxidized stainless steel nut).
Regular price for this heat shield is $69.99.
I am currently offering a group buy pre-order sale price of $59.99!!
I have the heat shields in stock but have not been powder coated as of yet. I am doing the pre-order to get a production run together and then will have them all done and shipping out via USPS Priority Mail Flat Rate box which costs $10.70 anywhere in the US. When checking out please make sure to select the USPS Flat Rate shipping option as other methods come up as much more expensive!!
Nice, im most likely purchasing an exhaust next month, so might be a while till I have the money to purchase one. I might wait for the carbon anyways. Thats if you produce them.
Originally Posted by Vinsfeld,Jul 15 2010, 03:03 PM
Would this be good for greddy turbo, or would blocking air flow be too much from engine itself?
I am not familiar with the greddy kit so not sure if it would fit. You can test fit one out since you are local and all.
As for airflow I don't think that would be an issue at all.
