NRG Engine Torque Damper
Old Jan 12, 2006 | 09:06 AM
S2X's Avatar
S2X
Former Sponsor
Angry NRG Engine Torque Damper
i just got my ETD installed.
another alternative for s2000 and available in 4 colors.
no mounts for the fuse box though.
groupbuy ---> https://www.s2ki.com/forums/index.php?showtopic=351434
Carbon Fiber Heat Shield with hole cut-out for Engine Torque Damper is in the works!!!
Old Jan 12, 2006 | 09:32 AM
ImportSport's Avatar
Nice Sam, you're really coming up with some great products
Old Jan 12, 2006 | 09:53 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
how do you install the fusebox?
Old Jan 12, 2006 | 09:56 AM
SIN3's Avatar
i have the stillen one for my g35,unless you car is putting out serious TQ numbers this is a usless mod.
i snaped two cog belts because of to much engine shutter. nice mod.
Old Jan 12, 2006 | 09:57 AM
GoTuningTommy's Avatar
Former Sponsor
Looks good! Too bad I've already got one.
Old Jan 12, 2006 | 11:08 AM
WyattH's Avatar
Yikes, I better go order 3 tomorrow!
Has anybody noticed ANY whatsoever gain with this (not in power, but maybe feel)?
Doesn't look like it can be used with a strut bar.. And since both are for looks, I may have to go with the Strut, muahaha...
Old Jan 12, 2006 | 11:54 AM
ruexp67's Avatar
I love the red.
I have seen reports from people with the "other" Engine damper that shifts were MUCH improved because of less rocking of the tranny. It could be placebo-itis, but I'd rock one.
Old Jan 12, 2006 | 12:10 PM
rosodigital's Avatar
got an idea you could make an L bracket that goes on in this order
L Bracket
damper
bolt
the L bracket will pass over the end of the damper so you can bolt down the box with nut, bolt and washer.
Old Jan 12, 2006 | 05:53 PM
S2X's Avatar
S2X
Former Sponsor
gains: NRG Engine Torque Damper for S2000. The damper reduce engine movement, vibrations and improve gear shifting by stabilizing the engine movement. Therefore horsepower is easily transferred to the wheels.
also i use mine with a the Cusco Titanium STB.
Old Jan 12, 2006 | 05:56 PM
S2X's Avatar
S2X
Former Sponsor
L Bracket
damper
bolt
this have pass our minds.
how about a Carbon Fiber L-shaped bracket for the fuse box?
