Project Spoon Caliper! :)
Old Oct 6, 2005 | 09:08 AM
Jaydem's Avatar
Default Project Spoon Caliper! :)
some of you have pm'd me asking to post pics of the 10mm spacer slapped behind my ce28n 50+ front
well here it is:
before 10mm
and with 10mm spacer
I was wondering if someone makes a spacer (10mm) that cover the whole diameter of the rotor to wheel surfaces....i dont like to gap here (anyone?)
also who can recommend extended wheel studs that i can use my closed-end rays lug nuts with??
thanks for looking
Jay
Old Oct 6, 2005 | 09:10 AM
Jaydem's Avatar
i acutally think the front ends look meaner now with the wheels spaced out 10mm....i just hope i dont rub!!
Jay
Old Oct 6, 2005 | 10:00 AM
kent-k's Avatar
what tires are you running. they look really square at the shoulder
Old Oct 6, 2005 | 10:23 AM
Mr. Francesco's Avatar
hum maybe ill do this now...
btw, get open end lug nuts. if you want to use your volk ones just get a new spacer with the studs built into them
Old Oct 6, 2005 | 11:01 AM
silviaks's Avatar
don't strip the studs!!! spacers are dangerous!
Old Oct 6, 2005 | 11:53 AM
ku_s_2000's Avatar
I agree. Spacers are fine if you have the right stud lengths to go with them. The stock studs are too short for the wheel lugs to grab onto and could probably start stripping because of the lack threading that grab onto the lugs. This happened to my Ray lugs when I was running 5mm spacers for the rear.
H&R makes good quality hubcentric spacer and stud combos that work awesome. I personally would suggest H&R if you're going the spacer route. Good luck.
Old Oct 6, 2005 | 11:59 AM
ApexMotorPro's Avatar
where can you get wheel spacers at?
Old Oct 6, 2005 | 12:01 PM
ideugene's Avatar
I believe COmptech makes longer studs
Old Oct 6, 2005 | 12:03 PM
Jaydem's Avatar
i cant get the spacer that has the bolt built already b/c evasive told me this work with 15mm...10mm is not enough to high excisiting oem bolt!!
jay
Old Oct 6, 2005 | 01:56 PM
F20_C's Avatar
I am pretty sure those are the Yokohama ES100's
