REQ: 17 inch work meister s1 2pc
i am going to get some work meisters and i am thinking about going 17s or 18s but i just want to see some pics of 17s on an s2k because i have seen 18s all over the place. thanks.
Good luck finding S1 2pc pics. Everyone (and all the ones you've seen thus far) only gets 3pc S1 wheels. I've been waiting to see pics of an S w/ 2pc S1s for years. Be the first and get them!, and post them up so I can see them!
For Work S1s, since the spokes are fairly short (for example, an S1 3pc 18" uses a 15" center, the 2pc uses a 16" center), I'd get the 18".
Well I just ordered my wheels... i got 18x8 and 18x9.5... i hope it looks clean. i was thinking about 17s but they don't make them in 1/2 sizes. i should be getting them in about a month and a half... i will post the pics when i get them.
Tho most ppl only go a max of 18x9.5 in the rear, you can actually fit an 18x10 w/ a +73 offset, and you can order that offset for the S1 2pc (offsets are available from +79 down). With a +73, you'll be able to run a 285 rear tire and not rub. Most people get an 18x9.5 with a +62 to +68 or so, which forces them to run a 265 tire max. If you go a bit higher on the offset (there's still room on the inside), you can go 18x10 w/ a 285. Plus, 285/30/18 is the same size as stock...any other wide 18" tire is off a bit and will change your FD, speedo, and odo.
Can't wait to see your wheels!
thanks man. i didn't wanna go 18x10 cause the tires would be too freakin expensive.... and i didn't wanna run 30s i actually wanna run 255/40s but i can't find any. but sometime in august... i can't wait either!
The new Falken RT615s come in 255/40/18. With that size tho, you'll be about 3.8% bigger than stock (so figure about that much drop in your FD, and error in the speedo and odo). I'm looking at the RT615s as my next tire also.
What color did u get? Ooh, it'll look cleeeeeeeeeaaaaaaaaaaannnnnnn!
