Someone create this!!!
Old Sep 27, 2001 | 10:59 PM
rstark's Avatar
Default Someone create this!!!
I need an image (preferably a vector image) of the tachometer for the S2000. Is anyone up to the task?
Old Sep 28, 2001 | 05:49 AM
Wesmaster's Avatar
[QUOTE]Originally posted by rstark
[B]I need an image (preferably a vector image) of the tachometer for the S2000.
Old Sep 28, 2001 | 07:58 AM
rstark's Avatar
[QUOTE]Originally posted by Wesmaster
[B]
I can do it, just won't be my top priority.
Old Sep 28, 2001 | 08:00 AM
Wesmaster's Avatar
[B]
Yes thanks!
Old Sep 28, 2001 | 08:04 AM
rstark's Avatar
You want the file in EPS or Illustrator format?
I guess it doesn't matter, as long as I can open it in Illustrator, but it will eventually used in Publisher. I just want it to be re-sizable without negative effects. I'm going to use it at around 3 to 4 inches long. Thanks again!
Old Sep 28, 2001 | 10:55 AM
Wesmaster's Avatar
Ok, I got bored here at work
Here it is:
Tach.ai (Illustrator)
Tach.eps (EPS)
Note: I went for the quickest, closest look, not exactness. Mainly that there may not be the exact same number of lines on the tach. I also had to do this based on pictures off the web, as opposed to taking one myself. If it's not perfect enough, I can take some more time on it later.
Old Sep 28, 2001 | 11:51 AM
rstark's Avatar
That looks great Wes!!! One request though, could you add a tiny bit more space between the letters that make up the 9000 RPM - not a lot, just a tiny bit more. Thanks again, you are da man!!!
Old Sep 28, 2001 | 12:05 PM
Wesmaster's Avatar
...could you add a tiny bit more space between the letters that make up the 9000 RPM...
Ok the files have been updated.
Old Sep 28, 2001 | 01:22 PM
rstark's Avatar
That's perfect! I owe you one!!!
Old Sep 28, 2001 | 03:16 PM
rstark's Avatar
One last request, could you make one with a transparent background? TIA
