Spacers added
Just showing some OptionSelect Spacers/extended studs I installed on my OEM's until I decide if I want to go aftermarket on the wheels. I was looking for a little bit more aggressive stance after the drop.
Only $88 for the pair and the quality was above my expectations.
15mm's on 255 tires on the rear. I'm debating if I want to install my 15mm fronts on 225's.
Thanks for the compliments so far.
Yes the rears can be a PITA if you don't have the proper tools. With the S the rear hubs need to be removed in order to fit extended studs. The extended studs are shown in the first picture I posted. I'm guessing any tire shop would be able to do the install in around 1-2 hours. I would think you'd get away for under 200 at a shop.
I'll try to post up a DIY since I took install photos while removing the hubs (just for that reason
I'll take some different angles tomorrow and put the fronts on. The fronts should be easy.
edit*** I'll post the camber specs I'm running as soon as I can find my last custom alignment specs
...They are around here somewhere... No rolling was required or will be required.
).I'll take some different angles tomorrow and put the fronts on. The fronts should be easy.
