Stopping MOD
GT-C's are sweet!!!!!! the only thing that i dont like about your car is, is that you got a sweet bbk on the front with puny brakes in the back...
BTW check your tire pressure... it looks low.
Yes the rears should have been painted at the same time as the install. The brakes started out a little soft but are now starting to respond to expectations. With the stock brakes so good, I did not expect a tremendous difference. The brake add was more a result of seeing how bad the Volks looked with the stock brakes/rotors.
Style thing. BTW: Good call on the air.
check your tire pressure... tires looks a little under inflated
you should drop it...would make it look better
