WORK REZAX
Old Apr 21, 2008 | 10:01 AM
pinoyk20's Avatar
Default WORK REZAX
hi guys! i haved found a rims that i liked the question is will it fit and look good on my s2000 with j's racing type s 2.0kit with spoon rear wide fender??? here is the specs:
BROKEN SIZE. 17x7 21ofset ,17x8 17ofset. newly refurbished. . PCD114x5.
here is the link:
http://www.autoindustriya.net/4sale/...s.php?id=26296
pls help me! i need adivices on this! thnks!!
Old Apr 21, 2008 | 10:09 AM
bullitt5897's Avatar
thats an extremely low offset... You will be very hard pressed to fit that in the stock body not to mention you will have no clearance for any kind of brake upgrades (BBK). Hopefully the more knowledgeable guys can chime in here. You might be able to fit them but with alot of work and I mean ALOT... besides using wider fenders with those you should be ok.
GL
Old Apr 21, 2008 | 10:25 AM
pinoyk20's Avatar
yup i have a j's racing type swide fender up front and spoon rear wide fender on the rear.. and also i think it will fit BBK because it is farther from the caliper......what do you think?? thanks!!!
Old Apr 21, 2008 | 10:43 AM
I think you should be fine. if it comes down to it you can always use a small spacer up front to clear the bbk
Old Apr 21, 2008 | 10:48 AM
pinoyk20's Avatar
cool thanks sir!!
Old Apr 21, 2008 | 11:49 AM
TrackStar's Avatar
There is noooo way those are going to fit under the fenders. They are going to stick out past the fenders more than an inch.
Old Apr 21, 2008 | 12:23 PM
the j's are what close to 45mm wider right and he is running 7inch up front just like stock ap2's just lower offsets it should fit...
stocks are what +55 in front and these are +21...
last time I checked 55-21=34 there fore they should fit with 11mm extra left over!
Old Apr 21, 2008 | 12:40 PM
spoons are 18mm wider and he is still going to stick out past those but with camber he might be able to fit them
Old Apr 21, 2008 | 01:57 PM
Panda's Avatar
If you have the J's Front fenders, they are the +40mm more on each side. You said you have the type s kit, which includes just the font bumper, side skirts, and rear bumper. Fenders usually are separate when people refer to the kit. So the wheel size I think will fit barely, but of course camber will take care of the rest. If you are still looking for wheels for that setup , I have my wheel setup for sale. (work S1's)
Old Apr 21, 2008 | 03:18 PM
spoolins2k's Avatar
It will fit with the wide fenders.
