S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
06+ organizer under passeger side dash
Old Dec 22, 2010 | 06:32 AM
k24accord's Avatar
Default 06+ organizer under passeger side dash
Bear with me as my explanation may not be the best. I know the 06+ models have a organizer of sorts that goes under the dash on the passenger side. I tried searching for it, but have no idea what its called and can't seem to find it on majestic's website. What is it called and will it fit 04-05 models?
Old Dec 22, 2010 | 06:53 AM
OH FO SHO's Avatar
Look under "Instrument Panel Garnish", I believe it is called the Pocket Assy.
77325-S2A-A50ZA 030 001 POCKET ASSY., INSTRUMENT PASSENGER (LOWER) *NH167L*
Old Dec 22, 2010 | 07:25 AM
mchau101's Avatar
this item will NOT fit a 04, trust me I I've tried.
Old Dec 22, 2010 | 09:49 AM
Carbon Blue's Avatar
how about the tiny dash compartment behind the drivers seat?? I cant find the key for that (not the center console). Does honda make em depending on vin code?
Old Dec 22, 2010 | 10:11 AM
ahrmike's Avatar
. I wonder why? Is it a dash interference or a door interference?
Old Dec 22, 2010 | 11:12 AM
mchau101's Avatar
the cutout on a 04 is smaller then the newer ones.
Old Dec 22, 2010 | 11:18 AM
ahrmike's Avatar
Ah, so its the entire dash.. I wonder if its possible to cut and stick the new section..
Old Dec 22, 2010 | 11:24 AM
Greg W's Avatar
Carbon Blue, what dash compartment is behind the drivers seat? My '05 AP2 has only a seat pocket, no compartment (other then the center ones). Is this a "double secret" compartment?
Old Dec 22, 2010 | 01:03 PM
xoz's Avatar
xoz
I think your referring to the actual "secret compartment", you use your ignition key to open it..
Old Dec 22, 2010 | 01:21 PM
zeroptzero's Avatar
I think someone has fit it on a newer S2000 but it involves major cutting and fitting work. In the end it isn't worth the cost of the part and the cutting work just for basically what amounts to a mail slot. It doesn't provide much storage, best used for map storage when driving, but who actually uses maps anymore , lol.
