S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
amp location
Old Jan 31, 2013 | 01:09 PM
hossman's Avatar
Default amp location
hey hey hey,
so i am upgrading the sound system on my 05GPW and i would like to have my amp anywhere but in the trunk as i want to keep the most amount of space possible....i have the jl stealthbox which is gonna help me keep my space or keep alittle bit of space..and i would like to keep my spare tire as i know with my luck i will get a flat as soon as i take it out...has anyone put their amp behind the seats?
Old Jan 31, 2013 | 01:13 PM
kryptonite's Avatar
Member
Spotter
Originally Posted by hossman
hey hey hey,
I thought about doing it behind the seats but it left little to no room fully mounted.
You can try and fit the amp under the passenger seat. There's a bit more room under there if I remember correctly than there is under the driver seat. Thing is you're minimizing breathable space so the amp will tend to and likely overheat.
Never thought of trying it but if you get a small enough amp, try hiding it somewhere under the dash
Old Jan 31, 2013 | 02:16 PM
hossman's Avatar
Originally Posted by kryptonite
Originally Posted by hossman' timestamp='1359670157' post='22306295
hey hey hey,
hey fellow oakvillian!
i thought under the seat but again overheating would be a pain and its a fairly decent sized amp so i might be outta luck and have to sacrifice the trunk even more
Old Feb 6, 2013 | 12:28 PM
Bingoig11's Avatar
I installed my amp (2 channels so a small amp) behind driver seat, vertically mounted.
Old Mar 25, 2013 | 06:54 AM
S2day's Avatar
I have two amps in my car. One behind each seat but it changed my driving position alot so I ended up putting that in the negative space underneath the soft top tray. I would recommend that but I had to take out some recycled foam they had in there but it all fit. I would recommend that location because it's all unused space
Old Mar 25, 2013 | 01:18 PM
dustin02rsx's Avatar
My amp fits perfect in this empty space
Could be a little tight for breathing. I may wire up a 12v fan to help keep it cool in there.
Old Mar 25, 2013 | 09:28 PM
drj5011's Avatar
i bolted in a piece of plywood to where the spare tire bolts into and screwed my amp on there. Hidden and plenty of room to breath
Old Mar 26, 2013 | 02:46 PM
Pics?
Old Mar 26, 2013 | 06:57 PM
drj5011's Avatar
Originally Posted by dustin02rsx
Pics?
shitty pic that i had on my phone but you get the idea
Old Mar 27, 2013 | 10:25 AM
Thanks for the pic. I was hoping you had both your amp and spare tire in there
