S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
Broadway Rear View Mirror
Old May 7, 2013 | 05:23 PM
s2kswag's Avatar
Default Broadway Rear View Mirror
What's up guys, I know this might sound dumb but I'm having issues installing my broadway mirror, My rear view mirror seems to sit high maybe because I'm a little bit taller (6'0) and have to have the mirror aimed higher and without the broadway mirror it touches the top pillar already. So when I tried to install it, it was aimed too low while touching the top pillar and I couldn't adjust it upward anymore. Has anyone else had this issue with their broadway mirrors ? Thanks !
Old May 8, 2013 | 06:28 PM
Arthas's Avatar
It fit perfectly for me with no issues at all,but I am short so I have the mirror aimed down.
Old May 10, 2013 | 04:18 AM
takeshi's Avatar
Doesn't sound dumb at all. People have had issues even with the stock mirror height on replacement windshields.
https://www.s2ki.com/s2000/topic/890...mount-problem/
https://www.s2ki.com/s2000/topic/100...ndshield-help/
You don't have many options though. You can either change the placement of the mirror mount on the windshield (and run the risk of cracking your windshield) or use a different mirror.
Old May 11, 2013 | 09:22 PM
russmp's Avatar
I had this issue when i first got my car, i couldn't get the broadway to clamp on, but i was kind of in a hurry.
i took my time putting it on as soon as i got home, the right half of the mirror hits the top near the map light, but i am a bit shorter (5'6"). i have the mirror aimed a little lower, i wish i could push it up a little higher but it just doesn't budge. My windshield is a replace tho. i just learned to deal with it
Old May 27, 2013 | 10:11 PM
YEGGT's Avatar
I'm 6'4".. the broadways don't go on very well at all.
I'm using a Spoon curved mirror.. sticks on with double sided tape. Much more than enough with that.
Old May 28, 2013 | 01:24 PM
teamvalorracing's Avatar
whats the point of the broadway mirror when you see edges of the rear window with the oem mirror anyway?
Old May 28, 2013 | 04:21 PM
NYGPW08's Avatar
mine does the same. I kinda monkey'd with it and got it to be where I need it by gradually forcing it into place. I'm your height too.
Old May 29, 2013 | 05:02 PM
icantbeseen1's Avatar
i have the spoon as well. a little on the expensive side but def. worth it and looks oem except with a blue tint
Old Jun 1, 2013 | 05:17 PM
Seven11's Avatar
with the top down, broadway mirror is the way to go!
Old Jan 9, 2014 | 10:43 AM
rockstar143's Avatar
I want the broadway because I always feel vulnerable sitting at a light with top down, I'd like to be able to look at everything going on around and behind me at all times.
