S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
Centre console trim polish
Old Aug 15, 2010 | 04:15 PM
Traffic Monkey's Avatar
Default Centre console trim polish
Hi all,
Just got my first S2000 last week and loving it. I'm looking to tidy up just a few bits and pieces, one being the metal surround that goes around the gear gator and two switches.
At the moment it looks grey in colour but I can see some nice shiney metal underneath where it's worn that's crying out to be polished.
The question is how do I remove this trim from the centre console to polish it.
Any advise would be really appreciated.
Old Aug 17, 2010 | 06:03 AM
sparrow's Avatar
You don't have to remove it... just eaither tape around it or be very careful... I left mine in the car w/ no protection and polished it by hand and vacuumed the crap it left afterwards
Old Aug 17, 2010 | 11:50 AM
Vagelis's Avatar
how could i polish this piece????
Old Aug 17, 2010 | 01:28 PM
sparrow's Avatar
u could just use some rubbing alcohol to get the material off
Old Aug 17, 2010 | 05:09 PM
Would rubbing alcohol do the trick? I was thinking of removing the trim and using a polishing wheel on the end of a drill which worked perfect on the gear knob allthough that was easy to remove.
Before I buy some, has anyone tried this method to remove the grey back to shiny metal.
Cheers
J
Old Aug 17, 2010 | 05:34 PM
sparrow's Avatar
rubbing alcohol is not expensive just grab a small bottle n try it.. I used it and it worked for me w/ some scrubbing
Old Aug 17, 2010 | 05:44 PM
Cheers Sparrow, I'll pick some up and give it a go. Should be a lot easier than removing the trim
Old Aug 17, 2010 | 05:45 PM
stonedS2000's Avatar
If that dont work take a heating gun (hair dryer) and a flat head and pop the two circle clips out and you can sand & repaint. Also loosen the flat silver clips.
Old Aug 19, 2010 | 04:00 AM
The rubbing alcohol worked perfect, took about half an hour and the finish is exactly what I was looking for
Thanks Sparrow, great tip
Old Aug 19, 2010 | 04:39 AM
sparrow's Avatar
