S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
CR Trunk Trim
Old Dec 23, 2010 | 10:24 AM
OldDog's Avatar
Default CR Trunk Trim
I'm removing my spare tire and would like to get rid of the bulge in the trunk. I assume the CR does not have a spare tire, does the CR have a different trunk trim? Flat instead of rounded?
Old Dec 23, 2010 | 11:34 AM
Jumpman2k's Avatar
Hrmm, I was under the impression CR's did have a spare, but either way, here is something to consider from the Electronics forum:
Flat cover:
https://www.s2ki.com/forums/index.ph...ic=214535&st=0
Semi-related -- amp rack:
https://www.s2ki.com/forums/index.php?showtopic=232978
Old Dec 23, 2010 | 01:10 PM
OldDog's Avatar
Thanks Jumpman2k, that's what I was looking for.
Old Dec 24, 2010 | 06:27 AM
zeroptzero's Avatar
the CR uses the same bulged panel as the other S2k's oddly enough. I was wondering if you could push the bulged area inwards so ti bulges the other direction. I removed my spare tire a while ago and replaced it with a pump and sealant system much like the CR uses.
Trevorh
Jan 7, 2017 07:09 PM
Laker
Jan 25, 2012 12:28 PM
chris S2000
Jul 12, 2011 03:27 PM
vasquezgno
Jul 15, 2010 03:57 AM
whitt1
Jan 13, 2010 02:30 PM
