S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
Door sills..
Old Jan 27, 2016 | 05:43 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Default Door sills..
How do you remove,and reinstall door sills whitout,breaking and scratching anything?
Is there a DIY somewhere???
Thanks.
Old Jan 27, 2016 | 07:10 PM
RickyLee's Avatar
door seals? r u planning to rob a s2k? jk
it is easy...but what seal?
softtop door seal or the bottom of the door?
but really.. it is easy. just pull gently.
Old Jan 27, 2016 | 07:28 PM
Door SILLS...got it???
Old Jan 28, 2016 | 05:22 AM
saving4one's Avatar
They just pop off. Wrap a screwdriver/pry tool with tape or cloth to protect from scratching (sill plastic scratches easily) and pry at the seam. They should just pop off by pulling with your fingers though, mine always have. First few times I washed the car I would pull up on the passenger side sill to drain water out from under it. One time it just popped off. I had a slight incline in my driveway, washing it with it backed in, instead of nose in, solved the water under the sill problem
Underside of sill has 3? plastic tabs (male) with metal v-clips that clip into hard plastic (female). They do not break as easily as say, door panel clips.
Old Jan 28, 2016 | 04:03 PM
RickyLee's Avatar
lol it is easy just use hand dont need tools..
Old Jan 28, 2016 | 06:24 PM
zeroptzero's Avatar
be careful in cold temps, there are little tabs on each of the two ends that will break off if you aren't careful. On the middle section just pull it up as the clips just pop up, on the two ends try to widen the ends prior to pulling up so the tabs don't break off .
Old Jan 29, 2016 | 02:50 PM
Thank's Guys,will wait till the temps warm up,Joey.
Old Jan 29, 2016 | 04:56 PM
zeroptzero's Avatar
Yeah I accidentally dropped one of my door sill covers on the floor of my garage last week and it shattered due to the temps, it was only about -8 degs C , what a pisser
s2konroids
Jun 1, 2009 03:18 AM
cheshire_carper
Jul 7, 2004 11:46 AM
Ender
Mar 5, 2001 06:42 AM
