S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
help with dash :[[
Old Feb 24, 2013 | 08:11 PM
mugginmike's Avatar
Default help with dash :[[
okay guys so i bought some of that 3m carbon fiber wrap and did my center console but i wanted to do my radio and climate control panels so i began to take off my dash but did not realize i had to lower my steering wheel to do so. so long story short i gave up and now my dash does not fit perfectly it has a gap near the bottom left corner of the vsa button i have an ap2 im going to try to take it off correctly tomorrow any tips ?
Old Feb 25, 2013 | 07:19 PM
croftoncustoms's Avatar
You domt remove the dash!
Two bolts under steering column will drop it down. then you can remove the cluster surround bezel.
Good luck
Old Feb 25, 2013 | 07:53 PM
mugginmike's Avatar
Thanks ! One of the clips on my concsole was bent but I fixed it
Old Feb 25, 2013 | 08:04 PM
icantbeseen1's Avatar
well heres some good instructions if you need them. obviously only part of this applies to you
http://www.qube-engineering.com/Docu...2_1.x_v1.0.pdf
jeantrong
Dec 25, 2017 02:04 AM
triumph14
Aug 31, 2015 05:28 AM
s2konroids
Jul 31, 2011 09:38 PM
mvs2k
Aug 16, 2009 10:40 AM
midnightmethane
Jul 22, 2006 08:09 AM
