S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
Loose Factory Rear View Mirror
Old Apr 25, 2016 | 07:58 AM
choppstixxx's Avatar
Default Loose Factory Rear View Mirror
Just thought I'd post some helpful info that I troubleshooted this weekend. Ever since I owned my S2000, the rear view mirror has never been quite tight or solid. This became a big problem when I installed my radar mirror mount. I read a few vague threads about similar issues, but none that really helped me. I ended up ordering all new internal parts for the base of the mirror (washer, screw, spring, and metal o-ring type disc).
Part #'s are:
76409-SL0-003
76410-SL4-003
76419-SL4-003
76420-SL4-003
Came out to like $19 @ my local dealership and was next day shipped to them for me to pick up. Super simple install, now the mirror is super tight with no vibrations etc.
So anyone that has a loose mirror, replace the hardware with the above and you'll be good to go!
Old Apr 28, 2016 | 09:16 AM
uh0h50's Avatar
Mine has been loose for too long. Just ordered the parts, thanks for sharing!
Old Apr 29, 2016 | 11:37 AM
You got it man, it really is such a cheap/easy fix. Just remember when your re-installing the parts on the back side (facing towards the window) the screw is reverse threaded. So you gotta turn it left to tighten it down, but that is it!
Old Sep 14, 2016 | 11:29 AM
Soviet's Avatar
Made a video of how to disassemble and re assemble the mirror for those that want a visual aid.
[media]http://www.youtube.com/watch?v=5D7l4BqgrWg&ab_channel=DIYGuys[/media]
Old Sep 4, 2019 | 01:11 PM
j0oftheworld's Avatar
Thanks! This is valuable..
Old Sep 21, 2019 | 03:37 PM
rmayhew's Avatar
Thanks for the help! Ordered the parts.....
Old Oct 7, 2019 | 10:09 PM
bradyn's Avatar
Thanks man, its all in the attention to detail. Ill add it to the list of maintenance for when I get mine.
Old Jun 12, 2023 | 11:53 AM
rvittori's Avatar
Hey folks, I ordered the parts and have tried to remove the screw using a #1 Philips. It is the correct size for screw but after a half hour, I cannot get it to budge. Does anyone have any suggestions?
I did not try WD40 yet. Trying not to make a mess.
Old Jun 14, 2023 | 04:23 AM
Chuck S's Avatar
I find my worn screwdrivers don't always work well.
Maybe a new, high torque #1 Phillips will help? Maybe a new, high torque #1 Phillips will help?
-- Chuck
Old Jun 23, 2023 | 07:33 PM
robb's Avatar
Sometimes if you put a piece of a rubber band in the threads of the screw it can help you get traction with the screwdriver.
