S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
Planted Rails
Old Apr 7, 2013 | 10:57 PM
YEGGT's Avatar
Default Planted Rails
I'm 6'4".. after looking through all the threads I'm considering the BC rails.
But due to the poor quality control described by some on these forums I found the Planted rails from 425 Motorsports:
http://www.425motorsports.com/plante...06-driver.html
They look fairly hefty and well made.. has anyone compared the two?
Thanks...
Old Apr 8, 2013 | 02:11 PM
SilverS2kF22C1's Avatar
Only buddy clubs I have seen have been side mounts, that planted mount appears to only be for bottom mount seats or to mount a slider set-up from another manufacture.
Old Apr 8, 2013 | 02:26 PM
afzan's Avatar
Buy the bc rails an have them re welded. I've seen planted bases with Recaro side mounts used for Recaro pole positions and the seats were higher than stock!
Old Apr 9, 2013 | 01:33 AM
thepoi's Avatar
My sidemounts (Sparco Revs) were way too high on Sparco mounts and the Sparco base (looks more or less identical to that Planted one), and I'm literally a foot shorter than you. I actually wanted a fixed base (no rails), so I ended up making my own mounts--when used with a narrow seat that can fit in-between the brackets, the seat can go all the way to the floor.
Old Apr 9, 2013 | 05:08 PM
PierreC's Avatar
I am quite interested in this. I am planning on putting Momo daytona Evos in the car. I am 6"2 and I need all the room I can get above the head to pass the broomstick test with the helmet. I assume pictures are going to be difficult to take, so could you post a sketch of your solution? o you think that installing momo or recaro brakets (modified if needed) could work?
Old Apr 9, 2013 | 05:10 PM
PierreC's Avatar
If you want to lower your stock seats, the Backyard Special low seat rails are the best solution, IMHO. I also removed some padding and beat the pan down, and it is fantastic for me. Now moving to race seats so that I can fit a harness for the track.
Old Apr 10, 2013 | 12:34 AM
thepoi's Avatar
My seats are actually out of the car right now, as I'm installing my sub belts. I'll take some pictures--they may give you some ideas. I could probably sell them for a reasonable price if there was interest, maybe I'll post a feeler.
Old Apr 10, 2013 | 04:52 AM
PierreC's Avatar
Old Apr 13, 2013 | 11:37 PM
YEGGT's Avatar
Yah, thanks.. I'm currently running the BYS rails, but even with a helmet on I'm slightly above the broomstick. Already have a Harddog bar...
I guess it's BC + Recaro PPs.
Old Apr 18, 2013 | 05:16 AM
hoangs2k's Avatar
I have a set of planted rails. Still New. They are thick and fit without any problems. (removed seats and mocked them up) Very good quality.
Trying to put in some DC5 Recaros and i heard that Bride RO rails are a direct fit. Looking for the driver side bracket is a pain though, cant seem to find them anywhere..
