Restoring finish on Ap1 shift surround bezel?
I just picked up an AP1 (2001) and was looking to restore the silver metallic finish on the shifter surround bezel. Are there any paint products that closely match this color. If not, what have you done to refresh it?
I'm also open to some of the 3M DI-noc cf wrap, but I'm unsure of the difficulty in applying/cutting the product.
I'd appreciate any tips, or experience you have regarding this.
Here's a good trick, remove the bezel and hit it with a cotton ball soaked in rubbing alcohol.
There is a shiny black/gunmetal chrome base coat underneath that looks better than a chipped and dull finish. I can't be any help as far as the color code to repaint it though.
Hummmmm, is the painted surface similar to the AP2 sliver trim around the roof/hazard button? If so the alcohol method to remove the clearcoat might be a way to refinish mine that's scratched up. I could probably strip the clear, and then re-clear the part with semi-gloss clear. Probably should do both that piece with the cover piece together so it looks the same.
Steel wool sounds a little too abrasive for the finish. I think I went with a 1000 grit paper. It took a little while, but the finish was smooth. Take your time on it, or you may have to strip off the whole thing and repaint if you damage the metallic finish.
if you want to see what the it will look like at the end (before doing it to your S), let me know. Calxtreme did it to my AP1 and it looks awesome!
