S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
S2000 Carpet
Old Dec 23, 2011 | 02:02 PM
NoFear791's Avatar
Default S2000 Carpet
I was wondering if anyone knows if a 04-09 carpet would fit in a 00-03. If it wont what is the difference between the two. Thanks
Old Dec 23, 2011 | 06:39 PM
Mister Jew's Avatar
Don't see there being any difference except on 00-01 models the carpet goes up to the center console.
Should work its pretty much same everything.
Old Dec 24, 2011 | 03:38 PM
Tony_05s2k's Avatar
06+ wont fit due to changes that were made to the passenger side. Not fully sure about the 04-05's but there is a better chance those will fit into an ap1.
Old Dec 27, 2011 | 04:25 PM
Chinatown NG's Avatar
06+ driver side will be the same...
06+ passenger side will not fit correctly. The side walls of the carpet will be about 2-3 inches taller then your 01. Also, the cargo net will be a different size...
It will work but keep in mind you will have extra holes for the mounting points for the cargo net area & the carpet might be a little more loose on the passenger side.
Old Feb 1, 2012 | 12:47 PM
JDM Junkyard's Avatar
any detailed installation tips? I have the 06 carpet and want to put it in my 04.
Old Feb 10, 2012 | 12:19 PM
WhiteAP1ftw's Avatar
This is a swap I recently just did on my own. 07 black into a 2001 that was red.
I have no issues with the fitment, and needed to trim nothing as far as the carpet went on the passneger side. All the body clips lined up fine as well. The two issues I have:
Like ^^^^ said, the holes for the little net are off. I don't plan on using a net, and was able to mask the holes fairly well.
Also, the dreiver's side has and extra cut out, I believe it is for the floor mat hooks that my 2001 did not have.
Other than those two things it was fairly straight forward.
B.C.
Sep 26, 2011 04:51 PM
RAIN H8R
Feb 8, 2009 06:34 PM
Ro_Ja Boy
Dec 15, 2008 10:25 AM
yosephs2k
Apr 10, 2007 01:48 AM
racecarpete
Nov 18, 2006 03:38 PM
