S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
soft top rivet rolling around
Old Feb 19, 2013 | 09:51 AM
redwing497's Avatar
Default soft top rivet rolling around
Hey guys. The top was replaced by the previous owner under the TSB and a new OEM soft top was installed. Ever since I've had the car, there's piece of a rivet that rolls left to right during harder cornering. It's inside the bar right above my head. I've lived with it for this long but I'd much prefer to remove it if it's possible. Any suggestions? Thanks
Old Feb 19, 2013 | 10:00 AM
lltysonll's Avatar
what I did to get mine out take a hard turn left or right. Removed the rubber car on the end of the frame bar and used a magnet on a stick but, didn't really work so I just fished it out with a coat hanger and eventually got it out.
Now I have another similar rattle not sure if it is another rivet or something loose inside the door panel. Ill have to get a passenger to listen for the noise. Doesn't bother me now that I have a exhaust.
Old Feb 19, 2013 | 05:07 PM
croftoncustoms's Avatar
There is one bar that does not have a rubber cap end. if its the case drill a hole in the bar and go for a drive.
Old Feb 20, 2013 | 07:06 AM
takeshi's Avatar
The shop used compressed air. I just drove around with the cap removed (they didn't quite get all of them).
Old Feb 20, 2013 | 07:50 AM
redwing497's Avatar
ok, thanks guys. So i guess i have to check if its the bar with removable caps. I'm 99% sure it's the forward-most bar
Old Mar 4, 2013 | 10:29 AM
LAp1's Avatar
I have the same problem! Let me know how this works out for you!
Old Mar 5, 2013 | 03:01 AM
freq's Avatar
Had a "tech weekend" at my place last weekend. one owner removed the rubber cap and the rivet fell out. we hit the tube w/ compressed air too, just to be safe.
Old Apr 18, 2014 | 08:44 AM
Se7inhand's Avatar
New S2K owner here with the same problem. Where exactly is this bar located on the car? I would so love to get rid of that noise. Thanks.
Old Apr 19, 2014 | 05:43 AM
takeshi's Avatar
You can't locate the noise? There are cross bars in the soft top frame. It will be one of those bars.
Old Apr 20, 2014 | 06:41 AM
Se7inhand's Avatar
Got it. Thanks.
