@Lancercool1992 Do you have pictures of your install? That would help everyone determine your situation as well as the viability of the rails and seat.
Also interested in this, I am 6'1-6'2 and need to be a few inches lower for track days. I had heard the base of the qtr-r was too wide for the PCI or EVS rails to get as low as possible. It's either this or the EVO II, I haven't compared the specs but eyeballing them next to each other the harness hole height and everything seemed to be almost identical to the EVO II.
Sorry for being all late. Below are the pics requested. With the position I have the seat I am rubbing slightly on the X bar with the EVS Roll Bar.
Here is with the bolt inverted as stated before using one spacer on the side mount
Another view of the same setup
Here you can see how much clearance there is with the clamp bolt. Not much.
If you mount the side mount first you will have no room to bolt down the seat on the front left. Its' best to get all of the seat mount bolts, and the right side mount bolted down before putting on the left side mount. I used a button head allen bolt that I got from the local hardware store.
With two spacers on the left side mount you will have more room, and use the clamp bolt in its normal position. Millimeters of clearance here.
Not sure if it will be any help, but I have been running this set up for over a year. I'm using the planted base with the sparco side mounts, and no sliders. When I first bought the qrt-r they sold me the planted side mounts with it but it didn't work. I also tried to use the sparco slider but the seating position was way too high.
I currently have this seat with the PCI Adjustable seat mounts on the widest setting. I wasn't able to go as low as I could since the locking hardware was hitting the bottom of the seat. Sent Brian at PCI a message and he said to flip the hardware so the nuts are inside the slider and to use the side mounts spacers. I flipped the hardware and got more clearance to lower the seat one more notch. I just need to find the spacers that came with these mounts to give it more clearance as it's barely touching.
I am 6ft and 34 waist
can you please show me how you achieved this with pictures/video? I want to use a slide rail without paying such a premium for both sparco base mount and separately purchasing their slide rails
