Spoon hardtop brackets
I recently bought a used spoon hardtop and it didn't come with any of the brackets or hardware I spoke to spoon usa and they said they do not sell them separately. I was wondering if anyone has some pictures and sizes of the brackets and hardware I'll need to install the top. I assume I can't use oem brackets correct me if I'm wrong. Thank!
I thought it is all the same except the bracket holding it to the rear where the softop is usually mounted and the two tabs that hold the 2nd hardtop to the main hardtop.
Might be able to contact Shine auto that makes a replica top and see if they will sell you hardware
http://www.shineautoproject.com/ It appears the rear brackets are different from spoon tops to mugen & oem so you will need those along with 3 extra brackets that go along the rear molding. |
Originally Posted by AE_Racer
Might be able to contact Shine auto that makes a replica top and see if they will sell you hardware http://www.shineautoproject.com/ It appears the rear brackets are different from spoon tops to mugen & oem so you will need those along with 3 extra brackets that go along the rear molding.
I also found this, they might be able to point you in the right direction.
http://www.soloperformance.com/Izzys...y_p_10732.html (Spoon Top owners, inquire before ordering). and here are the "rear" brackets, these look totally different from the oem & mugen style brackets. https://www.s2ki.com/s2000/topic/693...style-hardtop/ |
I also found this, they might be able to point you in the right direction. http://www.soloperformance.com/Izzys...y_p_10732.html Also, found this thread. Here's a picture of the rear most brackets and here are the "rear" brackets, these look totally different from the oem & mugen style brackets. https://www.s2ki.com/s2000/topic/693...style-hardtop/
Bump
Bump
Bump
