S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
Spoon hardtop brackets
Old Apr 2, 2015 | 08:45 AM
BenWise04's Avatar
Default Spoon hardtop brackets
I recently bought a used spoon hardtop and it didn't come with any of the brackets or hardware I spoke to spoon usa and they said they do not sell them separately. I was wondering if anyone has some pictures and sizes of the brackets and hardware I'll need to install the top. I assume I can't use oem brackets correct me if I'm wrong. Thank!
Old Apr 2, 2015 | 10:23 AM
croftoncustoms's Avatar
I thought it is all the same except the bracket holding it to the rear where the softop is usually mounted and the two tabs that hold the 2nd hardtop to the main hardtop.
Old Apr 2, 2015 | 06:26 PM
BenWise04's Avatar
I can understand the fronts being the same as for the rear brackets do you know where I could buy them? Or where they mount to? Also I have the brackets for the 2nd piece of the top sourcing a bolt for them shouldn't be too hard.
Old Apr 3, 2015 | 05:31 AM
AE_Racer's Avatar
Might be able to contact Shine auto that makes a replica top and see if they will sell you hardware
http://www.shineautoproject.com/
It appears the rear brackets are different from spoon tops to mugen & oem so you will need those along with 3 extra brackets that go along the rear molding.
Old Apr 4, 2015 | 08:58 AM
BenWise04's Avatar
Originally Posted by AE_Racer
Might be able to contact Shine auto that makes a replica top and see if they will sell you hardware http://www.shineautoproject.com/ It appears the rear brackets are different from spoon tops to mugen & oem so you will need those along with 3 extra brackets that go along the rear molding.
thank you! The number on the website is outta service I sent them an email hopefully they get back to me quickly
Old Apr 6, 2015 | 04:11 AM
AE_Racer's Avatar
I also found this, they might be able to point you in the right direction.
http://www.soloperformance.com/Izzys...y_p_10732.html
(Spoon Top owners, inquire before ordering).
Also, found this thread. Here's a picture of the rear most brackets
and here are the "rear" brackets, these look totally different from the oem & mugen style brackets.
https://www.s2ki.com/s2000/topic/693...style-hardtop/
Old Apr 12, 2015 | 04:13 AM
BenWise04's Avatar
I also found this, they might be able to point you in the right direction. http://www.soloperformance.com/Izzys...y_p_10732.html Also, found this thread. Here's a picture of the rear most brackets and here are the "rear" brackets, these look totally different from the oem & mugen style brackets. https://www.s2ki.com/s2000/topic/693...style-hardtop/
thanks sadly izzy doesn't make brackets for the spoon tops
Old Apr 12, 2015 | 03:47 PM
BenWise04's Avatar
Bump
Old Apr 13, 2015 | 06:01 PM
BenWise04's Avatar
Bump
Old Apr 18, 2015 | 06:34 AM
BenWise04's Avatar
Bump
