S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
Windscreen effectiveness?
Old Mar 19, 2011 | 01:10 PM
yourboysoap's Avatar
Default Windscreen effectiveness?
I have a 2000 S2000 and it did not come with a windscreen on top of my glovebox.
Does it really do a good job of reducing cabin wind or is it not really worth installing one?
I searched this and found nothing, sorry if this has been covered before.
Old Mar 19, 2011 | 01:23 PM
midnightmethane's Avatar
I'd say it's effective to some degree...however you should also consider the fact that esthetically it ties the roll hoops in very well
Old Mar 19, 2011 | 06:18 PM
icantbeseen1's Avatar
the stock on is ok. are you missing the whole assembly or just the windscreen itself. i would assume the whole assembly. One thing to look into is js2k.com windscreen or Ricks2k.com as you can get a tall version which would be more functional.
Old Mar 19, 2011 | 09:46 PM
Jumpman2k's Avatar
Not very effective, IMO. Haven't had mine installed for a while and can't really tell the difference.
Old Mar 20, 2011 | 09:39 AM
itsnoe30's Avatar
From 00 without to 01 with stock to 01 with tall, I haven't really noticed any difference, aside from the top one rattling all over the place and hitting the rear window. I noticed much more of a difference by cutting lexan to put in the hoops themselves.
Old Mar 20, 2011 | 07:31 PM
afzan's Avatar
When I put the windscreen up/down I can notice a difference in wind noise + wind in the cabin. It's not a huge difference but it's enough of a difference for me to try a taller windscreen (from JS2k.com)
Old Mar 22, 2011 | 06:46 PM
Moddiction's Avatar
Former Sponsor
There is a very noticeable difference for me. I have the Js2k taller version one and definitely reduces the in the cabin wind quite a bit!
Old Mar 23, 2011 | 12:42 PM
pmptx's Avatar
I have a taller one and it makes a world of difference.
The wind noise and temperature are def impacted. Windows up screen up I can drive in bitter cold and the knock down on the wind means the heater can keep up.
Old Mar 25, 2011 | 07:28 AM
rugsr's Avatar
i have the taller and it helps a lot
i also did the headrest inserts
Old Mar 25, 2011 | 08:05 PM
itsnoe30's Avatar
After taking my tall one off, the difference is huge at highway speeds.
