06+ Possible Test Pipe CEL fix ?
Originally Posted by leo520,Dec 12 2007, 10:44 PM
wonder if it can make ur car passed emmision with test pipe on.
I have the double antifouler method in my Berk TP. Has worked fine for at least 5k miles now.
if i'm going to be using the test pipe with stock exhaust and header, is the 60mm or 70mm more suitable? does the inlet and outlet of the 60mm and 70mm pipes have same diameter? if i use the 70mm with stock header and exhaust, is there going to be fitment issues? thanks in advance.
i'm using the straight one-piece defouler packed with steelwool. no problems so far on a 70mm invidia tp w/ stock exhaust. don't know if i needed the steelwool just did it after reading about cel fixes..
back when i was i driving a rsx, most guys got the 90 degree defouler to work when the standard/straight version would not. i had kpro so didn't have to do a mechanical fix.
