2005 vs 2006+ OEM CAT Difference?
i might be wrong but i think its angled slightly different and the o2 sensor may not bolt in.if you look at the floor pan where the cat is, its tottaly different between 00-05 and 06-09. ive ran the 06 cat, exhaust & sensor in my04 and they do bolt up together but i dont know if not having the other components will make a difference
Okay, I called Science of Speed. They said a 2004/2005 should match up just fine on the 2006+
Also, they said they've done extensive DYNO testing and have said that the factory CAT has almost no negative effect to power output.
