Sponsored by: CARiD
3mm Wheel Spacer
Old Feb 2, 2012 | 07:23 PM
S2k007's Avatar
Default 3mm Wheel Spacer
I need some 3mm wheel spacers for the front to avoid the wheel rubbing on the inside under full lock. I'm running 255 all around on 17x9 +63. So far I've only found one quality set- T1Rs. Although it doesn't say if it fits our front center bores. Does anyone know if these will work?
http://www.evasivemotorsports.com/Me...5250-T03-5H114
http://www.aj-racing.com/shop/produc...cat=478&page=1
The other set I found are the cheap ones on Ebay. Although I'm concerned about the quality as they look pretty flimsy. Anybody have these are recommend something else?
http://www.ebay.com/itm/JAPAN-KICS-3...#ht_4774wt_901
Old Feb 2, 2012 | 07:29 PM
dc2-2-ap1's Avatar
There was a guy in the marketplace selling a set of the t1rs about 2-3 weeks ago. If you can find that thread, he should be able to answer your question.
Old Feb 2, 2012 | 09:46 PM
99SH's Avatar
If you want quality spacers go here: http://www.wheeladapter.com/wheel_spacers.php
Custom made to your spec
Old Feb 2, 2012 | 10:09 PM
S2k007's Avatar
^ Thanks but that's a lot more than I want to spend on a 3mm spacer. Anhybody know if the Ebay kics spacer I linked on the op is ok?
Old Feb 3, 2012 | 09:20 AM
mavericckk..'s Avatar
the kics will fit and should be fine.
Old Feb 3, 2012 | 10:28 AM
jordannn93's Avatar
http://www.ebay.com/itm/380399783183#ht_2377wt_1270
I bought those for the rear of mine. They worked great
If they dont have any listed for the front center bore size, email then i'm sure they can make them.
Old Feb 3, 2012 | 11:53 AM
S2k007's Avatar
Yeah I saw those but only listed for rear. No 70.1 bore for front. I'll see if they have fronts.
Old Feb 3, 2012 | 12:55 PM
speedjunky01's Avatar
Why doesn't anyone use local machine shops?
I'm sure they can make them fit PERFECT and be of quality for no more then 50 bucks
Will take an experienced lathe operator about 30 min to make a set
Old Feb 3, 2012 | 02:58 PM
jordannn93's Avatar
Because you can get a good set for under $30 on eBay with out the hassle
Old Feb 3, 2012 | 03:24 PM
jordannn93's Avatar
If you message them, they can probably get you a set.
