adding a header
would adding a header without a tune with the stock cat make the car run lean, and can u add a test pipe with a o2 bung so u dont throw a code and not run lean or do u need tunes for that.
Adding a header alone will not make the car run lean. Most people typically don't run into that issue until they have a full header, test pipe, and exhaust. You could throw it on a dyno at that point to check the a/f at that point. As always, some sort of tuning option is best with modifications.
An intake, header, test pipe, and exhaust made my 2004 run lean and all over the place at WOT. I don't know AFR's prior to these mods as I didn't install the WBO2 until after all these were in place. It would hit over 14:1 at WOT.
ViperASR
Sep 7, 2012 05:35 PM
