S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
header and testpipe combo.
Old May 2, 2012 | 10:41 AM
thebattleforokc's Avatar
Default header and testpipe combo.
Have a skunk 2 header and wanting a hytech 3 in testpipe. Will these two match up or will the test pipe only fit a hytech header?
Old May 2, 2012 | 10:58 AM
cadams05nfr's Avatar
I am almost cearting the hytech test pipe is shorter because of the legnth of the header. but don't quote me on that. You need to know the legnth of both headers and the test pipe to be sure.
Old May 2, 2012 | 01:12 PM
Just talked to gt motoring,about the testpipe. And they said it would work. But I thank you for the help.
Old May 2, 2012 | 10:52 PM
06Estukay's Avatar
My 3" (76mm) test pipe is from Challenge, made by Hytech. It has a 2.5" inlet that has a conical transition to 3". If it's the same one I have, then yes, it will work.
Old May 3, 2012 | 10:36 AM
H22toF20's Avatar
I also have 3" hytech with my berk header. They make ones for there header and ones to replace the stock cat.
Old May 3, 2012 | 04:53 PM
OK thanks guys for the help. Think I will do the 3in testpipe,instead of the berk 70mm highflow. Want to see how the skunk 2 header and challenge exhaust will do with that type of setup.
ViperASR
Sep 7, 2012 05:35 PM
Trent06
May 11, 2012 06:26 AM
MasterForce
Oct 17, 2011 03:39 AM
WyattH
Aug 20, 2005 12:18 PM
