Advice on which ECU for Tune
Hi I was leaning towards a AEM S2 standalone until I did my research and found out that it doesnt support CEL readings =[. I like my warnings on my car so I am not willing to give that feature up. So I figured I will most likely have to go with a piggyback? So what are my choices for a My01?
Goals: I/H/E/HFC tune while keeping my CEL warnings.
What are my best choices? Thanks
if money wasn't a big concern then go with this. http://www.ballisticmotorsports.org/index....4&category_id=9
it's basically a greddy emanage on STEROIDS lol. i personally have it and i believe it's a very good investment. no need to go to a tuner everytime you mod your car other than FI, cams, or ITB's. if your strictly going to stay N/A then this is your best bet.
Thx for the info the Tuner im going to recommended Kpro since I DD my car alot. Any difference between the Haltech and Kpro? Pros and Cons? Ill go research it right now =p. Thanks for the info so far!
Kpro?
Just wondering what the need for CEL lights are? Do you still need to be able to pass a plug in SMOG test? If that is the case then the AEM might even suit you even more since you can swap that system out with the OEM ECU.
