Sponsored by: CARiD
af gauge
Old Jan 8, 2009 | 06:55 PM
kylemonster85's Avatar
Default af gauge
How much work does it take to install an af gauge say innovative and does it make a cel light come on?
Old Jan 9, 2009 | 09:12 AM
powerneedy's Avatar
it fairly easy you have to weld in a o2 bung unless your running a stand alone and have no need for your stock o2 sensors. if you just adding one in you
wiring is like wiring in any item power, ground, and maybe signal
Old Jan 9, 2009 | 01:45 PM
were should you weld the new o2 bung in on. should i weld it on the my test pipe or to the header?
Old Jan 9, 2009 | 03:01 PM
s2k aok's Avatar
test pipe.
Old Jan 9, 2009 | 03:04 PM
s2k aok's Avatar
the test pipe can be easily removed and taken to a welding shop and you can mount it (the bung) completely vertical but for a header you have to take the car in and they have to some how drill it and weld it.
Old Jan 9, 2009 | 07:24 PM
will the af gauge come with the bung or will they have to fab one up??
Old Jan 10, 2009 | 12:12 PM
whats better innovate or aem
Old Jan 10, 2009 | 05:44 PM
iam7head's Avatar
are you running a wide band or just narrow band off the oem sesnsor?
if you are running the signal off the oem o2 secondary then don't, it's going to be a flashing light show with hi/low reading only.
seansniper
Aug 1, 2012 10:39 AM
S2K913
Jul 4, 2008 11:51 AM
stena
Feb 16, 2006 11:58 AM
jdmdohcpower
May 23, 2005 05:00 PM
