Sponsored by: CARiD
Alignment on low drops.
Old Jun 30, 2009 | 10:09 AM
Boost76's Avatar
Default Alignment on low drops.
I have skunk 2 springs(8 coils all around). I was wondering, why is it that the wheels still looks butterfied & the alignment is suppose to be good? Am I missing something? Should I have them make it more positive? How much can stock camber adjust negative & positive? Thanks in advance.
Old Jun 30, 2009 | 10:43 AM
JP Money's Avatar
Butterflied? I guess you mean it has a dose of negative camber? You can probably get close to stock camber but having a little extra is not a bad thing. As long as your toe in is in check then you are good to go. Do you have your specs from when it was aligned?
Old Jun 30, 2009 | 10:47 AM
s2k dre's Avatar
It depends who does the alignment! theres alot of rookies that dont have any skills.
Old Jun 30, 2009 | 12:42 PM
starchland's Avatar
whats the drop on those?
Old Jun 30, 2009 | 01:55 PM
Boost76's Avatar
2 inch it says but on mine its way more... tires are almost tucked.
Old Jun 30, 2009 | 02:57 PM
starchland's Avatar
im thinking your gonna need some type of aftermarket camber correction to get it somewhat into spec
Old Sep 13, 2009 | 09:40 AM
Boost76's Avatar
Took the car to align & they couldn't correct all the neg camber. Does anyone in here use camber kits?
Old Sep 13, 2009 | 12:15 PM
05APdeuce's Avatar
no need for a camber kit. the car comes from the factory adjustable take it to someone who knows what they are doing. You want to run some negative camber front and rear just correct the toe.
Old Sep 14, 2009 | 03:12 AM
mikey k's Avatar
I dropped mine 1.5" and found I could not get the camber any lower than below with out affecting the toe.
This is because the toe contro arm is a fixed length and not adjustable.
Have a look at the Megan, T1R and J's adjustable control arms.
Old Sep 14, 2009 | 03:57 AM
vollrathian's Avatar
run camber dont be a puss puss
