Sponsored by: CARiD
Aluminum rear diffuser install
Old Mar 8, 2011 | 02:38 PM
  #21
siik_ap2's Avatar
deff want one for my ap2!!!
Old Mar 8, 2011 | 02:50 PM
  #22
Jphoa's Avatar
How hard was it to connect the 2 pieces together? You said the center bolt was a pain? What did you do to reach the center bolt? Or is there nuts welded in already?
Old Mar 8, 2011 | 03:00 PM
  #23
kaansahbaz's Avatar
Do you realize that you wont be able to lift your car up from your rear diff ?
Thats why Amuse gives you this thing that you install on your lower diff so you can install your diffusers and still use the diff
Old Mar 8, 2011 | 05:48 PM
  #24
HS2K007's Avatar
I have never jacked the car up under the diff. I always jack each side. Plus the front section is easy enough to remove if I need to
Old Mar 8, 2011 | 05:52 PM
  #25
HS2K007's Avatar
All three nuts are welded and threaded to a long bracket in the pictures. This will go behind the plastic bumper. It was a pain, because the bolts could be a little longer to help. You are compressing the plastic with your hand while pushing up on the bolt to get it to thread. Jordan said he was going to use longer bolts on the next ones, so this should be resolved. It is just a tight space and requires both hands applying pressure.
Old Mar 8, 2011 | 05:54 PM
  #26
HS2K007's Avatar
Also the center bolt I reffered to is the one that attaches the fin section to the underside of the bumper, not where the two pieces join
Old Mar 8, 2011 | 06:26 PM
  #27
Jphoa's Avatar
Also, how did you adjust the diffuser so that it will sit inside more? Is this something i can do myself? Or should i tell jordan?
Old Mar 8, 2011 | 07:34 PM
  #28
HS2K007's Avatar
You can tell him you want the same version that he made me. I asked for this to be modified and he made all the changes exactly how I wanted them. Tell him my name and email.
Steven Marimberga
hs2k007@aol.com
Old Mar 8, 2011 | 09:36 PM
  #29
Jphoa's Avatar
Steven Marimberga
hs2k007@aol.com
Thanks brother! I sent him an email earlier concerning the extra fins, ill just tell him to make it the same as yours, thanks again.
Old Mar 9, 2011 | 12:18 PM
  #30
street_ruler's Avatar
just a heads up, jordan has been making accessories forever. he used to make em for 88-91 preludes back in the day. I never bought from him but i remember the name
