I'm working through a build on a 2003 and recently purchased an OEM front lip. When I go to have it mounted I want to make sure to get the gasket that goes along the edge. My shop recommended Part # 08F03-SHJ-1200D but when I look that up it is for an AP2. Does anyone have any experience with installing the lip on an AP1 and getting the gasket as well?
Might work although it's an Accord part number not even for an "AP2" without the S2A in the part number.
Found the Installation Instruction sheet for my front lower spoiler and the gasket isn't even on the parts list nor are there instructions on how to install it -- but I know it's on my car and saw it in the box years ago. My gasket is black.
BTW I had my stone magnet front bumper refinished and paint matched when the spoiler was installed. Recommend you do the same.
-- Chuck
Thanks for the instructions Chuck. My lip is OEM for an AP1 and came new-in-box. I don't think I have a gasket or even the screws supplied but I'm going to go back and check the box carefully.
The genuine Honda factory spoiler typically comes painted and with the seal/molding already installed.
Where did you buy the lip and do you have a photo?
Lip kits that Honda sold also came with hardware.
08F03-SHJ-1200D is not specific to AP2's.
However, it is gray. Gray was only provided/spec'd on OEM lips and accesories for WHITE colored cars. All other colors use a black molding.
No reason you can't use 08F03-SHJ-1200D. Its just gray vs black.
It turns out everything was in the box under all the packing! Thanks again for the advice. I'm excited to get the build on and thankful for this place!
