Sponsored by: CARiD
AP1 oem axles SNAP?
Old Oct 4, 2011 | 05:05 PM
dgmnz's Avatar
Default AP1 oem axles SNAP?
FOR THE SECOND TIME NOW I LAUNCH MY AP1 WITH THE STAGE 4 CLUTCH AND MY DRIVER SIDE AXLE BREAKS.I WAS TOLD THAT I CANNOT DUMP MY CLUTCH AT ANY RPM. WHEN IT HAPPEN I DUMPED IT AT AROUND 5K RPM. CAN I DUMP MY CLUTCH OR NOT? IF IT MATTER I HAVE A LITTLE MORE POWER THAN STOCK BUT NOTHING CRAZY (N/A)
Old Oct 4, 2011 | 08:36 PM
ryaSco's Avatar
Old Oct 4, 2011 | 08:46 PM
DFWs2k's Avatar
You have to preload.
Sent using free Tapatalk - Android FTW
Old Oct 4, 2011 | 08:53 PM
dgmnz's Avatar
preload? care to explain
Old Oct 5, 2011 | 07:35 AM
deepbluejh's Avatar
How often do you do this? What tires are you running?
Old Oct 5, 2011 | 08:51 AM
dgmnz's Avatar
not often but i had just gotten my car back i wanted to see what it can do. i am on the oem wheels with some cheap street tires.
Old Oct 5, 2011 | 09:11 AM
DFWs2k's Avatar
Search. I've typed it out multiple times on this forum and it is also in multiple threads in the FI forum.
Old Oct 5, 2011 | 09:18 AM
dsthez's Avatar
i think preloading in this case would be to let the clutch engauge a little bit right before you dump it
Old Oct 5, 2011 | 01:30 PM
dgmnz's Avatar
makes a lot of sense, i do feel some play in the drive-shaft so if i preload it i should eliminate the play before dumping it. tomorrow the axles get put on again and ill test it out. thanks for the help
Old Oct 5, 2011 | 05:33 PM
Jorsher's Avatar
Preloading is like punching someone after you've placed your fist on their face. Lot less impact.
