Sponsored by: CARiD
AP2 tail light conversion issues
Old Apr 4, 2010 | 08:03 PM
B serious's Avatar
Default AP2 tail light conversion issues
I installed some AP2 tails on my AP1. I used the OEM gaskets and through the heavy rain today, I got a TON of condensation on the inside of my lights. The lights looked to be sealed just fine when I put them in.
The problem, I think, is that water is sneaking past the gaskets. I've heard of some people using silicone sealer to seal the gasket to the body and the light.
Anyone else have a similar issue and can you post the fix? Also, where would I apply the silicone? Just where the gaskets meet the body and where the gaskets meet the lights, I'm assuming.
Thanks for any help
Old Apr 5, 2010 | 07:12 AM
viets2000's Avatar
You might just buy new gaskets. The original gasket sometimes loses its sealing ability due to being installed on the original car for a long time, then removed. The gasket is permanently conformed to the shape of the taillight and the car. You can buy cheap gasket material and trace out the original gasket and use that. It should help.
DO NOT USE SILICON!!! It's ghetto and gross to remove and clean up.
Old Apr 5, 2010 | 10:51 AM
bouford's Avatar
agreed. try new gaskets for now. hope this diy can help as well.
https://www.s2ki.com/forums/index.ph...owtopic=183447
Old Apr 5, 2010 | 12:56 PM
CarbonCrew's Avatar
Or you can pick you up some closed cell weather resistant neoprene foam for ~$8 and have a ball cutting your own gaskets. I've purchased a sheet of 3/16" and have used it several times now making new gaskets for the S2k and my daily drivers. I've gotten close to 5 sets of gaskets on one 1' sheet.
You can find the 3/16" foam here:
http://www.mcmaster.com/itm/find.ASP?tab=f...hstring=8647K42
Get a thick or as thin as you like.
Old Apr 5, 2010 | 02:05 PM
B serious's Avatar
Yep, my friend's dad owns a HVAC company, so I was able to pick that stuff up for free. I just resealed the holes and we'll see how it goes with tonight's rain. It's in there nice and snug, so...hopefully, it'll be all good.
Thanks again guys.
JamieP
Jul 30, 2012 09:39 PM
Ecclesium
Oct 27, 2011 09:38 AM
toniotran
Oct 3, 2010 10:37 PM
Blue_S2
Mar 18, 2010 08:36 AM
velocityracer
28
Jan 19, 2008 10:40 PM
