Sponsored by: CARiD
Bad Catalytic Converter...options?
Old Jun 26, 2011 | 07:22 PM
bkowa092's Avatar
Default Bad Catalytic Converter...options?
Hey guys and gals,
Every once and a while my car throws a code for the secondary o2 sensor. I went to replace it today, and it appears the contents in my stock cat shifted, not allowing me to replace the o2 sensor. So what I'm wondering is what are my options that will not throw a CEL, will pass inspection, and emissions. What I found through the search:
Test pipe - cheapest, has a bung for the o2 so it won't throw a code, but will probably fail inspection and/or emissions
Hi-flow cat - a bit more expensive, will pass inspection no problem, shouldn't throw a CEL, but might fail emissions?
OEM cat - obviously the most legit option, but also the most expensive
Well guys, what are your opinions? I'm sure people have went through this before, so I would really appreciate the feedback. Thanks in advance!
P.S. I have a stock header and exhaust, and plan on keeping them stock.
Old Jun 26, 2011 | 07:28 PM
Saki GT's Avatar
Warranty it?
Old Jun 26, 2011 | 07:34 PM
bkowa092's Avatar
Originally Posted by Saki GT
Warranty it?
The car is not under warranty anymore.
Old Jun 26, 2011 | 07:39 PM
JmanS2k's Avatar
Go with a Berk hfc. I think the only state you won't pass emissions testing is CA but, I'm not entirely sure. If not, PM me. I've got an oem ap2 cat that I'm about to sell.
Old Jun 26, 2011 | 08:01 PM
Saki GT's Avatar
Originally Posted by bkowa092
Originally Posted by Saki GT' timestamp='1309145337' post='20721904
Warranty it?
Fed warranty is 8 years, 80k miles. Are you within that?
Old Jun 26, 2011 | 09:18 PM
bkowa092's Avatar
Originally Posted by bkowa092' timestamp='1309145667' post='20721916
[quote name='Saki GT' timestamp='1309145337' post='20721904']
Warranty it?
[/quote]
Thanks for the info man. It's an 06 with 54k, so yes I am within that. I never heard of this warranty before, do I just call Honda and tell them the situation and they fix it free of charge? The exhaust has never been modified.
Jman, tried to PM you but it wouldn't let me.
Old Jun 26, 2011 | 09:19 PM
xxGPWS2Kxx's Avatar
You can shift the honeycombs back to allow install of o2 sen. But good chance they will shift and break it. I would get tp and remember to borrowa cat or put urs bk o/ at least a week so the ecu records enough data to pass smog.jut six bolts to remove and put back on every two years.
Old Jun 26, 2011 | 09:34 PM
IAmTheRealAsif's Avatar
Get a berk HFC or asura if you can get a hold of them. You will probably like it more anyhow
Old Jun 27, 2011 | 12:58 AM
toniotran's Avatar
i've seen a few used oem cats in the fs listing for around $80
Old Jun 27, 2011 | 07:51 AM
Saki GT's Avatar
Originally Posted by Saki GT' timestamp='1309147261' post='20721971
[quote name='bkowa092' timestamp='1309145667' post='20721916']
Warranty it?
[/quote]
[/quote]
Yes, I just got a new cat put in under warranty - its a Federal reg so the dealership will replace it free of cost if they diagnose it as a bad cat, but it sounds pretty obvious that it is.
