Bar between Belt
Hi,
I read a lot on harness, racing seat, roll cage. I know all problems in case of impact with a safety system not correctly fixed and made to work as engineers think.
Just one question... If I buy a racing seat with its seat rail and harnesses mounted on factory receptacles (schroth), I have a problem only with shoulders... if I mount a bar between stock belt receptacles (on the stock rollbar), do you think it coul be safe?
I don't see any particular trouble, the only one is the fact that I link two rollbar, made to absorb impact separatelly, and probably this could be a problem in the way forces distribute on chassis.
Is there someone who produce this cross bar?.
Another question.... Is there any possibility to fix shoulder belt on sway bar between post suspension? Or in alternative make an addictional bar over it to fix belt. Just An idea, I don't know if it works.
Thanks
Thanks
nextinstant39
Mid-A Swap Meet
25
Apr 20, 2012 04:16 AM
bellwilliam
Jan 11, 2011 09:13 AM
