Sponsored by: CARiD
Berk test pipe
Old Apr 17, 2016 | 03:38 PM
06s2kid's Avatar
Default Berk test pipe
I got flashpro and im convinced i should buy a test pipe. What are yalls opinions on a berk test pipe 63.5mm? Comes with a "cel fix". Need help asap. I have no other mods. 100% stock. Does the brand really matter?
Old Apr 17, 2016 | 04:09 PM
Black_AP1's Avatar
I have a 70mm berk test pipe matched up to my j's racing exhaust. I have zero complaints about it fitment was spot on and no check engine lights.
Old Apr 17, 2016 | 06:27 PM
06s2kid's Avatar
I have stock exhaust, so would it be better to have the 63.5mm TP? do they both fit?
Old Apr 17, 2016 | 06:59 PM
NFR-S2k-'s Avatar
It's always best to match the test pipe diameter to your exhaust so if you're running the stock exhaust you should go with the 63mm. If you plan on upgrading to a 70mm exhaust soon then go with the 70mm and upgrade both at the same time
Old Apr 17, 2016 | 07:03 PM
Black_AP1's Avatar
^ This
Old Apr 17, 2016 | 07:05 PM
06s2kid's Avatar
Originally Posted by NFR-S2k-
Originally Posted by 06s2kid' timestamp='1460946451' post='23941084
[quote name='Black_AP1' timestamp='1460938174' post='23940986']
[/quote]
So what are your opinions on it? Will it give me a lot of rattle? Or raspy sound? Or will it sound normal without a problem?
Old Apr 18, 2016 | 03:18 AM
Chuck S's Avatar
Test pipe will stink. Literally, you will be able to smell it.
63.5m will match your system better. These pipes are cheap and you can change the diameter later if you fit an exhaust that can benefit from the larger diameter. Look here as these are commonly for sale in both diameters. Since they're just pipe there's nothing to wear out.
Start soaking the bolts in PBBlaster now so you can remove them later.
-- Chuck
Old Apr 18, 2016 | 09:22 AM
NFR-S2k-'s Avatar
Originally Posted by NFR-S2k-' timestamp='1460948371' post='23941099
[quote name='06s2kid' timestamp='1460946451' post='23941084']
[/quote]
[/quote]
Like chuck said, it will stink but I don't think it's That bad. I had a catless subie and It wasn't bad at all and after a while I didn't even notice it. It should add some volume and a little rasp. I don't think it's going to be a huge difference sound-wise but I've never heard the stock exhaust with a TP so I'm just repeating what I've heard
Old Apr 18, 2016 | 10:57 AM
Chance S2K's Avatar
I have the full Berk 3". Very nice piece.
Old Apr 18, 2016 | 11:57 AM
dv55xc's Avatar
I'm sure it's crazy loud, right?
