Sponsored by: CARiD
best sway bars? little help?
Old Apr 23, 2008 | 07:47 AM
INTJ's Avatar
Originally Posted by S2Race,Apr 22 2008, 08:32 PM
yes i want a more planted rear and less body roll. im starting to autocross and drive more at the track. i was up in deals gap and it broke loose 4 times on me... and on autocross ill need it solid all around. is the comptech kit good? front and rear? its like 70% stiffer up front and 120% or something in the back... i want my car to sit almost completely flat...
First of all, broke loose? What do you mean?
Second of all, the car stock has far more potential than many drivers...seriously. Take some track days with a decent company.
If you are going to SCCA autocross, then there are many rules with significant consequences. Talk to folks in the racing page.
Old Apr 23, 2008 | 07:56 AM
Kermdaddy's Avatar
Gendron.
Old Apr 23, 2008 | 08:36 AM
bighead's Avatar
https://www.s2ki.com/forums/index.php?showtopic=351694
if you're looking to get rid of oversteer, or "broke loose" DO NOT get a stiffer rear sway bar.
Old Apr 23, 2008 | 09:45 AM
S2Race's Avatar
alright well count the rear out, but a stiffer front will help keep everything planted better? and when i say broke loose i mean the back end lost traction and started to slide... so a tanabe is a decent bar? get a good front one and ill probably be set with that? and looking at the tanabe bar, it is only 20mm in diameter... isnt that kinda small? stock arent they 27 or 28mm? so how would this help roll? couldnt that make it worse? and what about the strut tower bars with the X fram that attatch all the way to the bottom as well as the struts? and the spoon X frame that goes udner the car? does the car already have one or is that just a replacement?
Old Apr 24, 2008 | 05:02 AM
vtec4life's Avatar
The tanabe bar is not 20mm it's 30.? but it's stiffer than stock, this will help keep the rear more planted if you get the rear bar your not going to be too happy, just trust everyone you don't want a rear bar a front bar will do you just fine and if you don't like it then get the rear,as for teh strut tower bars they don't do much I have the 4pt. x Tower bar and I noticed it was a little stiffer, but very very little, so it's not worth in imo and the X brace I noticed on mine the only difference is when you go over bumps it's less harsh and that's about it.
Old Apr 24, 2008 | 06:38 AM
Tyraid2K's Avatar
I've had the tanabe front sway bar on since christmas time and was able to feel the difference, car changes direction super quick now, It's not the most radical setup but I like a bit of oversteer. Other sways seemed too aggressive for me
Old Apr 24, 2008 | 08:37 AM
rudeS2k's Avatar
so how are the cusco front sways?..any good?..
Old Apr 24, 2008 | 12:28 PM
S2Race's Avatar
alright well i wont waste my money on the xbraces. or the 4pt strut. but i will get the tanabe bar. its inexpensive so...
Old Apr 24, 2008 | 07:30 PM
LostMotion's Avatar
I have the Cusco front and rear and I like the balance, but I haven't pushed the car to the limits yet so I can't say if maybe the rear bar is a little too heavy. I have pushed it probably 8/10ths and it's pretty good so far.
I suspect under certain circumstances I would get wheel lift though.
Old Apr 25, 2008 | 12:28 AM
1320performancefreak's Avatar
i switch to a ap2 rear sway bar and stick with my ap1 front. so far so good.
