Building Custom Exhaust
Hey so i am looking to add an exhaust too my 2000 AP1 and due to being broke i would like to try my hand at making my own. I am very mechanically inclined and my friend is a good welder so i should have little trouble with the fabrication but i have no idea what i would need. I know a want a single exit because of the power gains and weight saving. I also want a 3" exhaust. The info i need would be what muffler i should get as well as were i should buy the piping/muffler. Also what other parts would i need(gaskets, pipe fittings etc.). Finally how much do you think the total project would cost.
Thanks in advance for the help!
Hopefully you have access to a mandrel bender. Here's my suggestions ..........
http://www.jegs.com/i/JEGS/555/30911/10002/-1
http://www.jegs.com/i/JEGS/555/30723/10002/-1
http://www.jegs.com/i/PYPES/958/MVS19/10002/-1
http://www.jegs.com/i/Stainless+Works/842/TH3W/10002/-1
Originally Posted by blueducatikidd,Jul 25 2010, 11:59 PM
Building your own exhaust might backfire on you in the long run.
I'd use a vibrant 3inch muffler with a vibrant 3inch super quiet resonator.
I have done several cars with that setup, it always sounds decent and doesnt cost too much money
if you by a vibrant J bend you should have enough bends to do the whole exhaust.
Originally Posted by blueducatikidd,Jul 26 2010, 01:59 AM
my advice would be try to save up little by little till you can buy a decent used exhaust or new. Building your own exhaust might backfire on you in the long run.
"Mechanically inclined" but "no idea" what you need to fab up a cat back? Little bit of contradiction there. Single exhausts are getting cheaper e.g. HKS 75mm or try even a pre-owned system.
Originally Posted by gernby,Jul 26 2010, 07:24 AM
You could also consider replacing the 2 OEM mufflers with new cans. I was surprised at the power gains I got from replacing mine with a pair of Magnaflows. It sounds nice too.
For resonators, flanges and mufflers:
http://www.vibrantperformance.com/catalog/....php?cPath=1022
For tubing and bends:
http://www.mcmaster.com/#weld-tube-fittings/=85089s
