Sponsored by: CARiD
Bump Stops
Old Jul 30, 2009 | 07:00 PM
TheMuffinMan's Avatar
Default Bump Stops
Just did an S-Tech install with the help of another forum member, per his suggestion I just left the bump stops off. Any harm in doing this? I searched and it seemed the general consensus was just to leave them on and not even trim them.
Should this be something for me to do this weekend (put them back on?) Or should I worry about it? I realize they don't affect the ride height but prevent the shock from wacking anything and bottoming out.
Old Aug 1, 2009 | 12:10 AM
iam7head's Avatar
under no condition that you should run your damper without the bumpstop
that little piece of polyurethane foam is the last insurance you have to protect the expense damper.
All you need to send the damper to hell is one bump, the internal gut smaching itself will be enough set it leaking, esp when you are running with shorten suspension travel
the installer/fellow member obvious is not an expert at this, you need to trim it slightly(eibach actually have a diagram for this), but even running full length bumpstop is better than running none.
Old Aug 1, 2009 | 09:21 AM
All it took was 60+ views for a simple answer haha.
Appreciated. The install guide has .2 inches being trimmed off the bottom of the front and the rear left untouched. I'll be installing them shortly.
macr88
Mar 27, 2012 02:28 AM
s2kkkkk
Dec 20, 2010 05:12 PM
gusrock77
Socal Swap Meet
Sep 30, 2009 11:00 AM
Trent06
34
Jun 1, 2009 06:10 PM
